LB Connection Limit Detection Method
We have set a connection limit on the load balancer. If there is a way to detect when the upper limit of the connection limit is exceeded, please let us know.
We are considering detection via log monitoring, but we would like to confirm if there are other methods available.
- richaed
Cirrus
Is it possible to monitor the number of connections per VS unit using SNMP traps or resource monitoring?
I believe the OID you're looking for is the following but I'm not 100% because I haven't had a chance to test this on my lab F5.
.1.3.6.1.4.1.3375.2.2.10.13.2.1.3
The following is something you can check out.https://my.f5.com/manage/s/article/K13322
Additionally, you can pull the MIB information directly from your device to see everything that applies to your specific code version.- richaed
Cirrus
Thank you.
When I checked the status of the relevant virtual server via the GUI during the connection limit, it was displayed as yellow.
Can you set up an alert to trigger when the value for the following OID becomes 2 (yellow)?
.1.3.6.1.4.1.3375.2.2.10.13.2.1.2
- Kerry
Cirrus
pool::status i think in a irules will tell you if any pool members are available and accepting requests
