opers13_3280
Feb 06, 2011Issue with http and https VS
I'm having issues getting the following to work, two Virtual servers with the same IP 10.10.10.1:HTTP and HTTPS
Single HTTP pool configured. HTTP redirects to HTTPS VS assigned to the HTTP VS.
The goal is to have the HTTP VS with an irule redirecting HTTP to HTTPS VS and no pool assigned to HTTP VS.
When I configure the HTTP VS like that, nothing works..including the HTTPS VS.
But when I remove the irule and assign the HTTP pool to the HTTP VS both HTTP and HTTPS VS work just fine...not sure exactly what's going on.
virtual exchange-443 {
enable
translate address enable
translate service enable
snatpool none
pool exchange
destination 10.10.10.1:https
mask 255.255.255.255
profiles
exch-oneconnect
exch-owa-443
exch-owa-tcp-443
serverside
exchange_owa_SSL
clientside
tcp
clientside
persist exch-owa-cookie-443
virtual exchange-80 {
enable
pool
snat none
pool exchange
fallback persist none
profiles
exch-owa-80
exch-owa-tcp-80
oneconnect
persist exch-owa-cookie-80
pool exchange {
lb method round robin
snat enable
nat enable
slow ramp time 0
monitor all http
members
10.20.20.10:http
up
10.20.20.11:http
up
rule exch_owa_http to https {
HTTP::redirect "https://10.10.10.1/owa[HTTP::uri]"
- hoolio
Can you create a custom HTTP profile and configure the 'header to insert' as "FRONT-END-HTTPS: on", add that profile to the HTTPS virtual server, add the redirect iRule to the HTTP virtual server, remove the pool from the HTTP virtual server and retest? If you run into any issues, try using a browser plugin like HttpFox for Firefox or Fiddler2 to see what's happening from the client perspective.
Aaron - opers13_3280
Hi aaron,
I think I found the issue..it was the irule.
I installed HttpFox and noticed the extra /owa in the redirect.
https://10.10.10.1/owa/owa
I removed the /owa from the irule redirect URL and now it seems to be working fine.
