krisdames2's avatar
krisdames2
Sep 20, 2022
irule help - pool command and ERR_RTE Routing problem
I am running on 14.1.4 and I have an iRule on an HTTPS virtual in route domain 1 with an iRule to do content switching based on URI. The new pool I am switching to has members that require SNI. It is failing even though I have connectivity to the pool members via the command line (while in the same route domain) so it does not seem to be a firewall issue. The server SSL profile I am using is providing the hostname required by the pool members.
    set foo 0
    if { [HTTP::uri] starts_with "/foo/" } {
        set foo 1
        pool my_pool
when SERVER_CONNECTED {
    if { $foo } {
        SSL::profile /ROUTEDOMAIN1/serverssl-mypool
when LB_FAILED {
    log local0. "DEBUG2: event info: [event info]"
    log local0. "DEBUG2.1: lb info: [LB::server]"
The error given by [event info] is:
<LB_FAILED>: DEBUG2: event info: ERR_RTE
<LB_FAILED>: DEBUG2.1: lb info: /ROUTEDOMAIN1/my_pool 13.x.x.x 443
Any ideas about ERR_RTE ?
  • I know this is old, but it came up on a Google search.
    We name our pools ending with _HTTP or _HTTPS, or other things. We then assign the vip a serverssl profile and have this in an irule:
        if {!([LB::server pool] ends_with "_HTTPS") } {
            SSL::disable serverside
    • krisdames2's avatar
      krisdames2
      Mohamed_Salah_,
      I only have one SSL server profile attached to the virtual. Are you suggesting additional profiles must be attached to the virtual if I want to call them in an iRule with SSL::profile? The SSL server profile that I am calling in my iRule does have the server name that the new pool members need.
      • I think you should start considering generating a new tcpdump and decrypting the traffic using the below article.
        tcpdump -nnnveti 0.0:nnnp host "client IP" and port 443 -s0 -S -w /var/log/pcapname.pcap
        Decrypt traffic and assign the irule on the virtual server:
        https://support.f5.com/csp/article/K12783074
