images and hot fixes
Dears, Im doing a security assessment for the F5 device, and I found 2 vulnerabilities on my image which is 10.2.4 hf2 as per f5 documents : one of them can be solved by hf3 and the second can be solved by hf4
so if i installed hf3 then installed hf4 over it, will this fix the two vulnerabilities ?
- StephanManthey
Nacreous
Hi Hamza,
- Seth_Cooper
Employee
Hi Hamza,
Hotfixes are cumulative or "rollup" hotfixes. This means that everything included in HF3 will also be included in HF4.
https://support.f5.com/kb/en-us/solutions/public/8000/900/sol8986.html
If you are willing I would recommend going to HF-9 as it will have even more fixes included that HF-4.
Regards,
Seth Cooper
- jgranieri
Hello Hamza,
Typically the latest HF will cover roll-up fixes for the previous HF but Its always good to go through the read-me files to ensure that is the case. If your considered a HF upgrade you might want to go with HF5 which covers the bash shell vulnerabilities patches.
Special engineering hot fixes are not covered in typical new HF releases.
