Chakravarthi_P1's avatar
Chakravarthi_P1
Aug 01, 2012
HTTPS passthrough with HTTP:Host validation
I am trying to setup a HTTPS passthrough where SSL certs would be configured on Servers..
DNS :
test.mydomain.com --- 59.40.33.11
web.mydomain.com -- 59.40.33.11
dev.mydomain.com -- 59.40.33.11
Virtual Server
59.40.33.11
Nodes:
10.33.84.21 (test web server)
10.33.84.42 (production web server)
10.33.84.52 (dev web server)
Now, based on fqdn, i want to divert the traffic. I am able to achieve this with HTTP by sing swith option
But not able to do with HTTPS as I am not able to use HTTP / fasthttp with SSL passthrough
Can someone help me here ?
Regards
Chakri
  • hoolio's avatar
    hoolio
    Hi Chakri,
    In order to inspect the HTTP host header value for all browsers, you'd need to decrypt the SSL and parse the HTTP headers.
    If you have a controlled population of users and guarantee they use more current browsers, you could potentially do this by reading the TLS server name indicator from the SSL handshake:
    http://en.wikipedia.org/wiki/Server_Name_Indication
    Here's an example from Joel Moses showing how you can parse the TLS SNI value:
    https://devcentral.f5.com/wiki/iRules.TLS-ServerNameIndication.ashx
    Aaron
  • Hi Aaron,
    Thank you for quick response and reference links..
    Users may attempt from various versions of browsers.. So TLS server name may not be suitable...
    To decrypt the SSL, can I have multiple SSL certs (for three different URLs) on same Virtual server ?
    Regards
    Chakri
  • No, you can only have one clientssl profile per VIP. But there are alternatives. In this thread: https://devcentral.f5.com/Community/GroupDetails/tabid/1082223/asg/50/aft/2163786/showtab/groupforums/Default.aspx
    nathan suggests using a wildcard SSL cert, and I suggest using SANs on a certificate to cover the names you'd like to use.
