Http / https health monitor issue
I tried to create https health monitor , but it is not worked
curl -v https://d-p-m-d.bms.rome.com:10221/login
StatusCode : 200
StatusDescription :
Content : <!DOCTYPE html>
<html xmlns="http://www.w3.org/1999/xhtml"
<link rel="stylesheet" href="css/material-components-web-3.0.0.min.css" />
<link rel="stylesheet" href="css/auth-shared.css" />
<link rel="...
RawContent : HTTP/1.1 200
Set-Cookie: XSRF-TOKEN=a00fgfhjjffa-efc7-4ahjj9-bahhgf-1099ccgf21ghgcdd2; Path=/; Secure,locale=en; Path=/
X-Content-Type-Options: nosniff
X-XSS-Protection: 1; mode=block
Strict-Transport-Securit...
Forms : {login-form}
as a send string
GET /login HTTP/1.1\r\nHost: d-p-m-d.bms.rome.com:10221\r\nConnection: Close\r\n\r\n
receive string
HTTP/1.1 200
Do not include port in string
tryas a send string
GET /login HTTP/1.1\r\nHost: d-p-m-d.bms.rome.com\r\nConnection: Close\r\n\r\n
if you need to monitor a port different than the one used in pool member, use alias
- Teerarat
Service Port should be config on pool member and remove port on Hosrt
- Ozzy
sorry I do not understand your explanation.
as i said before
use
do not use port ":10221" in the monitor
