mxu_65255's avatar
mxu_65255
Sep 04, 2009
How to filter syslog messages
I tried to filter out some syslog messages using syslog include, but it seems filter does not work. My syslog server gets all syslog messages.
This is my reference:
http://devcentral.f5.com/Default.aspx?tabid=63&articleType=ArticleView&articleId=155.
My device:
Product: BIG-IP
Version: 9.4.7
Build: 320.1
BaseBuild: 320.1
Edition: Final
My syslog.inc
syslog include "
destination remote_server {
tcp(\"192.168.20.83\" port (514));
filter f_local0.info {
facility(local0) and level(notice) and match(\"AUDIT\");
filter f_no_local6 {
not facility(local6);
destination d_ltm {
file(\"/var/log/ltm\" create_dirs(yes));
log {
source(local);
filter(f_local0.info);
filter(f_no_local6);
destination(d_ltm);
destination(remote_server);
Another thing I did was setting remote server:
bigpipe syslog remote server 192.168.20.83, otherwise, I could not get syslog.
Is there anything wrong with the configure? How to I filter syslog for this version of f5?
Thanks,
Minquan
  • hoolio's avatar
    hoolio
    Hi Minquan,
    I think the issue is with the the log statement. Also, there is no need to recreate objects which already exist if you're not re-defining them with modifications (like destination d_ltm).
    To undo the past changes, you can edit the /config/bigip_sys.conf file and remove the configuration section, syslog {} and then run 'b load'. This will update the syslog-ng.conf file in /etc/syslog-ng (linked to /var/run/config/syslog-ng.conf).
    Then try this for the syslog include file:
     syslog include "
     filter f_local0_audit.info {
     log {
        source(local);
        filter(f_local0_audit.info);
    You should use the syslog include file method or the 'b syslog remote server x.x.x.x' method, but not both.
    You can use 'b syslog list all' to see the entire syslog-ng configuration running in memory.
    Aaron
  • Hi Aaron,
    Thank you very much! Your solution works perfect for me.
    Minquan
