HA Failover between two Datacenters
I currently have three Host Load Balancers with LTM Guest, with GSLB.
In datacenter 1 is two Host standalone w/two Guest in HA Failover / Synchronization - GSLB.
In datacenter 2 is one Host standalone w/one Guest in standalone - GSLB.
I am creating another set of three Guest for application isolation, two in datacenter 1 and one in datacenter 2, with no GSLB, due to application limitations of not using FQDN.
Is if feasible to create a HA Failover/Synchronization between three Guest, even though they are in separate datacenters (450 miles apart).
If so, what are some precautions that I should be aware of?
Regards,
Larry
- Larry_Wilks
Altostratus
Thank you for your response. Looks like reply from zamroni777 put me in the right direction.
- Melissa_C
Moderator
Hello Larry_Wilks
I saw you got a few community responses and wanted to see if those had helped answer your question? If they have or if you have received an answer elsewhere I want to encourage you to update your post and mark as solved. However, if you are still needing assistance please update with that and we will see what we can do to get you an answer.
Thank you for being a part of our community!
-Melissa
if the app doesnt have fqdn, you can use Route Health Injection.
basically, both DCs use same vip for the vservers of the app and the vip is advertised to ospf/bgp.
routing network will select best dc.Hello,
I suggest first to Measure RTT and packet loss between DCs. Aim for very low packet loss and stable latency. If latency is high/variable, do not rely on connection mirroring or DSC state sync for session continuity.
BR
Aswin
