C_P_15991's avatar
C_P_15991
Apr 10, 2007
Firepass and Dynamic Grouping using Radius
I need to setup the Firepass to get groups (profiles) from Radius server which is running under RSA Authentication Manager. The radius ships with RSA AM and it is based on Funk Steelbelted Radius.
So far I configured the Radius and RSA AM to be used for authentication as well as for dynamic grouping but the Firepass does not seem to be getting the group info.
I am using a utility called NTRADPING and I can see the Group attribute getting returned but the Firepass doesn't see it. I am using attribute 11 (Filter-Id) on the radius that was recommended by F5.
Does anyone have such configuration os any other dynamic configuration so that I can double check either the Radius or the Firepass and make sure that they are configured correctly?
I did contact F5 support but I can't get the necessary support I need.
Thanks in advance.
