Allan_66523
Dec 12, 2011Design Help
We have a new virtual web environment and would like to use one external IP for all the sites hosted by the new environment. I will be natting one of our external ip addresses to 192.168.20.54 which would be the main VIP. I was thinking about putting an Irule like the one below on this VIP. Is this the best way to accomplish what i am trying to do or is there a better way?
switch [string tolower [HTTP::]] {
"test.xyz.com" { virtual test_vip }
"hello.xyz.com" { virtual hellow_vip}
default { virtual default_vip}
- nitass
Employee
if all virtuals use same setting e.g. profile and its parameter, i think using pool instead of virtual command may be better.
just my 2 cents. - hoolio
I agree with Nitass, it's probably simpler to use pools not separate virtual servers for this.
Aaron - Allan_66523
The reason I was thinking of using virtual is because some of these sites will have SSL Certs that may be different. Would that change this design? - hoolio
The client SSL profile will have already been used by the time you parse the HTTP headers and the HTTP_REQUEST event is triggered. So I assume you mean different server SSL certs/keys. For server SSL, you could select the profile from the iRule using SSL::profile < profile name >:
http://devcentral.f5.com/wiki/iRules.ssl__profile.ashx
Aaron - Allan_66523
Would it be better to use HTTP Classes or IRules to do this? - hoolio
I'd use an iRule only as using an HTTP class won't allow you to select a server SSL profile.
Aaron
