Create Domino LTPA token on F5 problem
I'm trying to use the code at
http://per.lausten.dk/blog/2009/06/how-to-create-a-ltpa-session-cookie-for-lotus-domino-using-f5.html
to create a Domino LTPA token but I am getting the following error showing on the Domino server:
Token does not lead with 0 [Single Sign-On token is invalid].
The token should begin with the version number 0123 e.g. from the code
set ltpa_version "\x00\x01\x02\x03"
However, after decoding the token and then looking at it in a hex editor the version number shows as:
C0 80 01 02 03 .......
Can somebody explain to me why the \x00 is being changed to C0 80 please?
I've experimented putting other numbers in thefirst position to see what happens e.g. \x01\x01\x02\x03 and the hex readout looks correct i.e. 01 01 02 03. It only fails when I use a \x00 in the first position.
Thanks for any suggestions.
Jeff
- Jeff_Green_4244NimbostratusHi everyone,
- Jeff_Green_4244NimbostratusF5 have asupplied a workaround that seems to be doing everything correctly. We're going to test more thoroughly before declaring victory. The relevant line in the code is:
Create binary formatted token. set ltpa_token_raw_bin [binary a* $ltpa_token_raw]
when RULE_INIT { set ::DEBUG 0 set cookie_name "LtpaToken" set ltpa_version "\x00\x01\x02\x03" set ltpa_secret "b64encodedsecretkey" set ltpa_timeout "1800" } when HTTP_REQUEST { Do your usual F5 HTTP authentication here Initial values set now [clock seconds] set creation_time_temp [expr { $now }] set creation_time [format %X $creation_time_temp] set expr_time_temp [expr { $creation_time_temp + $::ltpa_timeout}] set expr_time [format %X $expr_time_temp] set username [HTTP::header "username"] set ltpa_secret_decode [b64decode $::ltpa_secret] First part of token set cookie_data_raw {} append cookie_data_raw $::ltpa_version append cookie_data_raw $creation_time append cookie_data_raw $expr_time append cookie_data_raw $username append cookie_data_raw $ltpa_secret_decode SHA1 of first part of token set sha_cookie_raw [sha1 $cookie_data_raw] Final not yet encoded token set ltpa_token_raw {} append ltpa_token_raw $::ltpa_version append ltpa_token_raw $creation_time append ltpa_token_raw $expr_time append ltpa_token_raw $username append ltpa_token_raw $sha_cookie_raw Create binary formatted token. set ltpa_token_raw_bin [binary a* $ltpa_token_raw] Final Base64 encoded token set ltpa_token_final [b64encode $ltpa_token_raw_bin] Insert the cookie HTTP::cookie insert name $::cookie_name value $ltpa_token_final Loop through the list of Cookie headers to remove superfluous trailing semi-colons (known F5 issue) if they exist. Save the Cookie headers to a TCL list set cookie_headers [HTTP::header values "Cookie"] foreach cookie_header $cookie_headers { Check if the last character is a semi-colon if {[string range $cookie_header end end] eq ";"}{ HTTP::cookie remove LtpaToken Insert the header without the semi-colon HTTP::header insert Cookie [string range $cookie_header 0 end-1] } else { Insert the original header HTTP::header insert Cookie $cookie_header } } Remove Authorization HTTP header to avoid using basic authentication if { [HTTP::header exists "Authorization"] } { HTTP::header remove "Authorization" } if {$::DEBUG} { binary scan $ltpa_token_raw H* ltpa_token_raw_hex log local0.debug "LTP_TOKEN raw Hex: $ltpa_token_raw_hex" binary scan $ltpa_token_raw H* ltpa_token_raw_hex_bin log local0.debug "LTP_TOKEN raw_bin Hex: $ltpa_token_raw_hex_bin" set ltpa_final_decoded [b64decode $ltpa_token_final] binary scan $ltpa_final_decoded H* ltpa_final_decoded_hex log local0.debug "LTP_TOKEN decoded Hex: $ltpa_final_decoded_hex" } }
- Jeff_Green_4244NimbostratusThat alomst came out correct. The relevant line was:
- hooleylistCirrostratusHi Jeff,
- TortiAltostratus
i stay in front of the same challenge like jeff and try to implement LTPA token creation incl. Reverse Proxy with SSO. This is all new for me. We use 10.2.2 @ LTM incl. ASM.
So, if i try to create an irule with Jeff's code from above i get an syntax validation error in Irule editor:
--> [invalid option "a*" must be: format scan] [a*]
so for me, it looks like the line should be replaced by this:
set ltpa_token_raw_bin [binary fromat a* $ltpa_token_raw]
can someone confirm that behaviour?
Thx
- John_45612Nimbostratus
Hi Team. Anyone have this working still? We are running BIG-IP 11.3.0, Domino 8.5.2, and I am struggling to get the code to produce a valid encoded token. Can anyone share an example of the set ltpa_secret "b64encodedsecretkey" field, to give me a clue to what this should look like? Is this a direct copy out of the LTPA document in Domino LTPA_DominoSecret field, or do I need to change that value prior to insert into the iRule? Thanks in advance!
