Nikson_M's avatar
Nikson_M
Icon for Cirrus rankCirrus
Jan 08, 2025
"Chassis fan unknown status." logs on a virtual F5 device.
Folks, I am trying to understand why would an virtual F5 device give FAN related errors.
Any idea?
I do not have much details for now as one of the customer has this issue. All I got to know was virtual F5 gives FAN errors.
  • probably the virtualization host adds virtual fan or virtual acpi power management device into the vm config.
    i suggest you check on it.
  • Hi Nikson,
    Ensure the BIG-IP VE software is running the latest version or patch. Check the release notes to see if this is a known issue.
    Br
    Aswin
