kkuzhal's avatar
kkuzhal
Apr 29, 2024
Using okta as SSO to login F5 GUI
Hi All,
Greetings..!!
Currently we are using local user accounts in f5 to login. We have different users with different roles on f5.
In our organization we are using okta for other apps authentication. Is it possible to have Okta for logging in f5 with SSO. If yes, please share the article or guide with the required configurations.
Thanks in Advance,
K Kuzhali
  • As far as I'm aware F5 management login only supports local, radius, LDAP and TACACS+ authentication and doesn't support any other modern auth like SAML, OAuth, OIDC etc.  We can check for other responses to see if it's something doable.
